RE: Typhoon
<<One of many fine details in this design is the curve between the cowl and canopy. So instead of using foam here, I will use balsa. To help preserve the curve I temporarily will use a balsa stick to bend the top longeron upwards and I hope the curve will not flatten out when sheeted. >>
Why not cut a shaped stringer from 1/4" sheet? I wish I had thought of this when I built mine!
