RCU Forums - View Single Post - 120 size 3d capable plane
Old 05-15-2004 | 01:32 PM
Spaceclam's Avatar
Spaceclam
Default RE: 120 size 3d capable plane
agreed on the yak, i just got mine and i guarantee that you will not be dissappoited. the quality is like nothing i have ever seen before in an arf. sence everything is about as slose to perfect as you could ever find, i give the quality and construction 5 out of 5 stars. i could not find a single thing wrong with it. instead of using cheap hardware they actuyally use the dubro stuff and even an included pull/pull rudder. CF wingtube and composite LG are things you usualy have to pay extra for but are included in this arf. the covering job is amazing. the fuse is beyond light. it's a yak so the fuselage is round, and it is 8 inches in diameter at the cowl and is 64 inches long and weighs only 1.8 lbs. but it is not flimsy. i know a guy who does full power blenders with his ys 140 in it and it takes it just fine. check it out at www.extremeflightrc.com and you will see what i mean. i've got a ys 110 waiting for it as well.
