Here's the spec's:
3W-106i B2 Cylinder capacity: 6.47 cu.in
Power: 11 HP; 8 kW
Bore dia.: 1.73 in
Stroke: 1.377 in
Speed range: 1200-8500 rpm
Weight: 6.32 lbs incl. ignition
Crankshaft: 3 Ball bearings
Connecting rod: Needle bearings on both ends
Gasoline-Version: 1 : 50 - 1 : 80 Mix
Ignition: 6,0 V
Propeller 2-bladed / Ã* 2 pales: 24x10; 24x12; 26x10; 26x12; 28x10; 30x8
Propeller 3-bladed / Ã* 3 pales: 20x14; 22x11; 22x12; 24x10; 24x12; 25x12
Here's where you get them:
http://www.3w-modellmotoren.com/engl...toren_com.html
