The short standoffs are the omes that are used on the DV, and I believe you can still use the slim line muffler. Yes the antirotation pin needs to be brought down about 1/8th of an inch on ALL of the planes. It is a simplle fix that will just make it so your elev. trim will trim neutrel. It is not that critical as far as getting it to the thousandths, just make sure to keep it equal from the bottom of the fuse
Chip
ORIGINAL: OnEdge
Chip,
I received my Double Vision last Thursday and have been going through the Instructions on CD-ROM. I have some questions.
1. The Motor Mounting Template that is posted on your website is different then the one on my CD-ROM. It doesn’t look like I will be able to use the 2.5inch stand offs that came with my DA 50R and Slimline Pitts Muffler? Do you happen to know what the length I will need to cut them at?
2. One of the procedures in the Manual says you need to relocate the rear stabilizer anti rotation pin by using a round file by 1/8 inch. The picture above this caption seems to show the location to be correct already? Do I need to perform this procedure? What is the correct measurement of this hole from the bottom of the fuselage?
