I have a new Brison 3.2 (1.5 gallons) and can't get it to run right. It has already dead-sticked on me twice.
I know that the HS needle should be between 5/8 to 1 & LS needle 1.5 to 2.5.
Here is what my settings are: HS: 1, LS: 1.5
With the LS at 2, my engine would cut if running at idle and suddenly throttled up. Now the engine burbles at mid throttle.
I am running 89 octane gas with Stihl oil at about 1:37 mix.
Also, the idle is high and the engine won't cut even when the throttle is closed all the way (Yes, I have tried it manually also)
TIA.
Cheers & Happy landings
