RCU Forums - View Single Post - Lighting 2 pro RTR?
Old 05-17-2004 | 12:08 PM
elmo-uk-
Default RE: Lighting 2 pro RTR?
Hi M8Y
Ul about the arm, because its such a new model. hardly anyone holds stock. they have to order off www.mirageracing.com which is why it takes so long. [:@] take a look gives you all the prices if you havent already.
with the engine that was supplied with the rr, do you find that the rpm at which it operates, fluctuates in a way that sometimes its fast then sometimes it dont go above say 25mph wierd. i have run it in properly and was fine for about 2 weeks then one day i got it out without any tweaking, it reduced in speed now it will not go above 40 without running it super lean. i mean i have it turned below 2 1/2 turns from closed on the high speed needle. My low speed is fine and is set to 3 turns so is ok on mixture.
This is only temporary and has had only 2 tanks through it at this level but want to return.
ANY IDEAS WHY THIS HAPPENS[&o]
AND HOW TO CORRECT.
