RE: 2 engine planes
You might want to check ezone out they specialize in E-flight.
Campy Having never tried twin electrics I'm not disagreeing with you but if each motor draws 10amps then you have a current draw of 20 amps wouldn't twice that be 40 amps
Again just thinking of it from a household wiring perspective the load on a given circuit is Based on the combined amount of usage (current draw) of the devices using the circiut Correct Is it not??? A 15 amp circuit supports an unlimited number of devices UP to a 15 amp current draw before the breaker trips.
