RE: Great Planes <span class=
Basin, did you mount your battery behind the wing? If not, your experience is substantially different than everyone else who has posted here with this model. And if you search around, you'll find other threads where at least two other fellows experienced the same cowl misalignment my plane shows. That seems to be a GP theme, as I've noted the same problem exists with the Lancair.
