RE: Simulators
Real flight is $200.
Then you can purchase add ons for $30 a pop. I there there are four or five. I only have a couple add ons.
[link=http://www.realflight.com/]real flight[/link]
I already knew how to fly when I bought Real Flight. I could fly the heck out of the trainer, no fear. But I kinda flew like a grandma with my four star.... Circles around the field with a loop or a roll here and there, nervous as hell do try anything else. I bought it so I could experiement different maneavers that I was too chicken to try at the field.
Now I only get the feeling where my stomach is going to explode every now and then when I loose orientation. It used to be a constant feeling take off to landing. I was a nervous wreck. A lot of it can be contributed to real stick time, but real flight definetly helped.
It helped my landings and take off tremendously also.
It helped me out probably more than I even realize.
You can fly with people online also.
Like has been said, its not the same as flying in real life, but it is pretty close. I doubt that you will be disapointed if you get it.
I probably have a biased opinon because I have real flight. Do some research. Check out the others that fasterthanlife mentioned.
Good luck,
Wings
