RCU Forums - View Single Post - Programming Futaba 7CAP Help
Old 05-18-2004 | 05:51 AM
max42's Avatar
max42
Default Programming Futaba 7CAP Help
I bought one of the new Futaba 7CAP radios and am trying to set it up for an Ultra Stick. The manual leaves something to be desired for anything but basic setups. I have the following configuration: 2 aileron and 2 flap servos, each going to separate channels; 1 servo for each rudder, throttle, and elevator channels.
ch1 - aileron (L)
ch2 - elevator
ch3 - throttle
ch4 - rudder
ch5 - flap (L)
ch6 - flap (R)
ch7 - aileron (R)
Has anyone programmed this configuration into a 7CAP?
I have attempted it the last few days but not having much luck.
I also have a question regarding throttle cutoff.
I can set the throttle cutoff OK but my question is about the switch assignment. The default switch seems to be the elevator dual rate (A). If I have dual rates set and also the throttle cutoff set on the same switch how can this perform both functions. I'd hate to be flying at low motor and hit the high rates and kill the engine. How can the switch do both? Or should I change switch assignments?
How do most people setup the throttle cutoff switch assignment? []
thanks for any help
