As per request
3-seperate posts of pics.
This one
" 1/2A"
"Wing Ding"
The fisrt four are of the "Beast".
An ugly wood hulled w/.48 showing the twin rudder hook-up.
Dispite the uglyness, it's a screamer...!
__________________________________________________ _______________
The next one, is of a 1/2A under construction. As "Pro27" would say, it's WOF.
The next three is the "Wing Ding" also under construction.
The hull is 37" x 17" and all 3/16" fiberglassed plywood. Ready to run weight will be close to 10 lbs.
The wing is fiberglassed balsa. And can be adjusted in height to accomadate any size prop.
I don't know at this time what engine I'll use. I may go with a 25cc ?????????
__________________________________________________ ________________
