RCU Forums - View Single Post - dingo down on power?
Old 05-18-2004 | 05:26 PM
darkvader's Avatar
darkvader
Default RE: dingo down on power?
What could be the reason to have a Dingo "down on power", ( from normal APC 16x12 - 8600 rpm CP 30% Heli to 7600 rpm ). I've noted that the disc valve ( piece 29 )came loose time to time because the retainer screw ( piece 31 ) unscrew itself. Than i adjust the clearence between disc valve and back plate and screw again the Retainer screw, and the motor goes ok. But after 2 or 3 flights came again the same problem.
What could be the major reason for that?
