RCU Forums - View Single Post - Kioritz runs slowly
Old 05-18-2004 | 10:58 PM
airbr
Default RE: Kioritz runs slowly
Well I am no expert but check your timing it may be retarded and if that is not it your rings might be broken or broken wrest pin or piston or are you runiing the motor in the wrong direction some of those Kioritz have a dual shaft could it be that you are using the wrong end.
There is a whole list of things that could be wrong.
