New JR PCM 9 possible bug
Got the new JR PCM9 and I think there is a bug in how the mixes work
Basically I have a delta jet with 2 elevons per wing. Therefore its I'm using the delta wing mix and mixing in channels aux 3 and 4 to elev/aileron
All ok until I move the sticks quickly.. The AUX 4 servo runs SLOWER!!!! and drags quite significantly behind the Ail servo. To the extent that if I move the Ailerons quickly I end up with crow brakes on one wing
Its not the servos, Rx or battery as I've swapped everything around. I've proved it right down to AUX4 mixing. If I run the same mixes with aux1,2 or 3 all is well
Can anyone help.... hopefully its me and aux4 is programmed elsewhere to do something else...
David
