RCU Forums - View Single Post - Hard Starting Engine
Old 05-19-2004 | 08:28 AM
cbsmith
Default Hard Starting Engine
I have an OS .15CVRX that has about 2 gallons of fuel through it. It has never been run lean and still has lots of compression even when its at operating temperature.
The first time it is started for the day it starts on the 2nd or 3rd pull. However every time after that it takes at least 10-15 pulls to get it going. It doesn't matter if I let it cool or not before starting.
The other problem I am having is that sometimes it will be running great and then go really rich and bog down for a few minutes. The it will go back to normal on its own.
Can an airleak at the carb or backplate cause either of these problems? The engine does not overheat. When it is running good the temp is around 210-230. I have replaced all of the fuel line already and it didn't make any difference. Would resealing the carb and backplate help? If not, what else could be the problem?
Chris
