RE: Effect of moving CG?
The center of gravity must be ahead of the location on the airplane where all the aerodynamic forces operate, the neutral point (NP). This location depends on a whole herd of things, but much experience has shown that having the c.g. about 10% ahead of this point ensures a flyable airplane.
With most conventional configurations, the c.g. then is nominally located between 25% and 35%. The 25% location normally results in a very stable airplane, as the restoring moment due to its location ahead of the NP. The closer the c.g. is to the NP the more manuverable the airplane.
I don't know of any easily accessible method of computing the NP, so the "rule" is the 25-35% thing, for a normal configuration.
The NP is generally found (after some tedious work) to be around 40%.. Can be less, can be more, but that's a nominal location.
25% to 30% is probably safe for your Eindecker.
