RE: wooden props VS plastic
I really like the APC props. I switched from a master airscrew to an apc(same size and pitch) on the same motor, and it seemed to me that there was less lag time from when I punched the throttle to when the thrust kicked in.
I have yet to get one that needed balancing. I always check them anyways. In contrast, Master Airscrew props have terrible balance, and I've had several that were so far out of balance, that it was unsafe to try and properly balance them.
The wood props are nice, and the different ones I used(top flite and zinger) were balanced very well. Hit the ground, and you're done.
APC props don't like the ground either, they always seem to have one blade snap off at the hub.
Master Airscrew props are definitely the most durable in my experience.
