Originally posted by K1jets
Different subject, but I have been told the TGA struts can handle some really rough & bumpy grass fields.
Please elaborate of your problems taxiing.
I'm concerned because I have a set on order for my Roo. TGA informed me that there are different spring settings that can soften them up. I was going to use TGA because I've seen older Robarts break on rough grass before.
Thanks...
They are adjustable? I didnt know that!
They are very strong!
This field is very rought for a small tired plane from what I can tell, when it gets up to speed the aircraft starts to bounce. The nose wheel being spring loaded didnt help mine, I am going to check into adjusting it, that will help alot, mine is too soft! Where did you read that?
