RCU Forums - View Single Post - Effect of moving CG?
Old 05-20-2004 | 05:53 PM
abufletcher's Avatar
abufletcher
Default RE: Effect of moving CG?
Paul, thanks in large part to your earlier advice on modifying my BUSA Eindecker 40 is has almost ceased to be a BUSA Eindecker! The only part of the kit I ended up using was the wing and I split that in two to be able to have a full cockpit. I also changed the way the servos were mounted (I prefer them hidden). But I'm sure I'll still need nose weight.
ID:	134391   Click image for larger version
