RCU Forums - View Single Post - What is wrong with all this ??????
Old 05-21-2004 | 08:49 AM
C_Watkins's Avatar
C_Watkins
My Feedback: (10)
Default RE: What is wrong with all this ??????
Absolutely.
Here are the FCC rules on the matter: (BOLD and colored text are my own emphasis)
(Edited my post for formatting... the post was too w-i-d-e for some reason.)
PART 95--PERSONAL RADIO SERVICES--Table of Contents
Subpart C--Radio Control (R/C) Radio Service
Sec. 95.207 (R/C Rule 7) On what channels may I operate?
(a) Your R/C station may transmit only on the following channels (frequencies):
(1) The following channels may be used to operate any kind of device
(any object or apparatus, except an R/C transmitter), including a model
aircraft device (any small imitation of an aircraft) or a model surface
craft device (any small imitation of a boat, car or vehicle for carrying
people or objects, except aircraft): 26.995, 27.045, 27.095, 27.145, 27.195 and 27.255 MHz.
(2) The following channels may only be used to operate a model aircraft device:
MHz
72.01
72.03
72.05
72.07
72.09
72.11
72.13
72.15
72.17
72.19
72.21
72.23
72.25
72.27
72.29
72.31
72.33
72.35
72.37
72.39
72.41
72.43
72.45
72.47
72.49
72.51
72.53
72.55
72.57
72.59
72.61
72.63
72.65
72.67
72.69
72.71
72.73
72.75
72.77
72.79
72.81
72.83
72.85
72.87
72.89
72.91
72.93
72.95
72.97
72.99
(3) The following channels may only be used to operate a model surface craft devices:
MHz
75.41
75.43
75.45
75.47
75.49
75.51
75.53
75.55
75.57
75.59
75.61
75.63
75.65
75.67
75.69
75.71
75.73
75.75
75.77
75.79
75.81
75.83
75.85
75.87
75.89
75.91
75.93
75.95
75.97
75.99
(b) You must share the channels with other R/C stations. You must
cooperate in the selection and use of the channels. You must share the
Channel 27.255 MHz with stations in other radio services. There is no
protection from interference
on any of these channels.
(c) Your R/C station may not transmit simultaneously on more than
one channel in the 72-76 MHz band when your operation would cause
harmful interference to the operation of other R/C stations.
(d) Your R/C station must stop transmitting if it interferes with:
(1) Authorized radio operations in the 72-76 MHz band; or
(2) Television reception on TV Channels 4 or 5.
(e) [Reserved]
(f) Stations in the 26-27 MHz range are not afforded any protection
from interference caused by the operation of industrial, scientific of
medical devices. Such stations also operate on a shared basis with
other stations in the Personal Radio Services.
(g) Stations in the 72-76 MHz range are subject to the condition
that inteference will not be caused to the remote control of industrial
equipment operating on the same or adjacent frequencies or to the
reception of television transmissions on Channels 4 and 5. These
frequencies are not afforded any protection from interference due to the
operation of fixed and mobile stations in other services assigned to the
same or adjacent frequencies.
[48 FR 24890, June 3, 1983. Redesignated at 49 FR 6098, Feb. 17, 1984,
and amended at 50 FR 37857, Sept. 18, 1985; 52 FR 16263, May 4, 1987; 57
FR 40343, Sept. 3, 1992]
