RCU Forums - View Single Post - Plan paper shrunk
Old 05-21-2004 | 01:21 PM
bryris
Default Plan paper shrunk
I am building an LT-40. Finished the left wing perfectly, then started on the right. I chopped the main spar and rear spar off at the ends as the instructions called for. Then I went to line up the pre-grooved trailing edge and it didn't line up with the plan this time. To make a long story short, I had to razor saw about a 1/4 inch off the scrap wood that I had previously cut off of the main and rear spars and CA it back to the ends to make the spars long enough to accept that that W5 rib.
Has anyone else has this problem?
Will the CA'ed ends be as strong and secure as if the wood were long enough in the first place?
