RCU Forums - View Single Post - Mixing problem using the 9C, Problems mixing elev and flap together.
Old 05-21-2004 | 07:26 PM
Blackie's Avatar
Blackie
Default Mixing problem using the 9C, Problems mixing elev and flap together.
Before giving this problem and asking for help, I have already done a search through the Fataba Faq and RCU, with no results.
Using a 6 channel receiver and a single elevator servo, I have channel 1 for right side aileron and channel 5 for left side aileron, I have already gone into the parameter setting and made the proper changes ch5&6. Went into the flaparon setting and turned it on. Both ail1&2 are all set at +100. flap1&2 are set at +&-100.
Using mix setting number 2 turned on, with flap as slave and elevator as master, both link and trim set to on and using switch G in the center position for on, the up position for off. Adjusted the amout of throw for both left and right side on the flap setting.
Heres the problem, switching G to the on position, only the right side aileron of the mix is working hence (channel 1). When I give up elevator only the right side aileron moves in the same direction as the elevator "spoilerons". When I give down, only the right side of the aierons moves down "flaps"
I have tried using the gear function as the slave, adjusting both ail1&2 in the flapron settings +100 and -100 al both left and right side but no effect.
Blackie
Edit in:
Before posting this post, I found the solution to my problem, but I decided to go ahead and ask this problem question anyway as it still poses a problem. The solution I discovered was right in front of me the whole time. I simply swapped the battery connector with the left aileron placing the power in channel 5 and moving the aileron to the 6 channel.
Blackie
