RE: Fire Extinquishers??
keep an extinguisher close to hand when starting. tell your assistant that in case of fire check you first, plane second. from some of the answers i read some people do not apprecite the energy in an ounce of gas. a few ounces of spilled glow fuel is hardly a problem whereas the same amount of gas can cause a flash fire. you also need an electric fuel pump designed for gas not glow fuel.
