I would not use them.
The connection is not hard and permanent.
If anything comes loose, you have a crash and a totaled plane.
ORIGINAL: Cappy69
Question.... I have one of those plastic Rx battery cases that I have from a car radio....the ones you put batteries in. Is there anything wrong with using those ? I have several sets of hight quality, brand name NiMH bateries.....around 1800 ma, and a good charger for them. I was wondering if it was ok. I plan on securing the batteries in the case with either zip ties or rubber bands and then wrapping it in foam and adding rubber bands to hold the foam. This way I can have more flying time without the need for buying battery packs. I do have a second Tx pack though. This is just a temporary thing until I build up my equiptment "arsenal"
Adam
