RE: WATER COOLED
As long as the boat stays moving in the water, not idling but runnig at a decent speed, you shouldn't need a water pump. These are mostly used on boats with a clutch and those that putt around in the water.
If the motor is getting too hot, you may have a water flow problem elsewhere.
