RCU Forums - View Single Post - Pull-pull systems and bellcranks...
Old 05-23-2004 | 01:10 AM
abufletcher's Avatar
abufletcher
Default Pull-pull systems and bellcranks...
I'm having trouble trying to layout the fuse servos (thottle, rudder, and elevator). Here are the basic problems:
1. Becasue the engine is mounted inverted the trottle control rod has to enter the fuse just about a 1/4" off the floor.
2. I'd like the cables for the rudder pull-pull system to run close to the floorboard (under the pilots seat)
2a. Is it OK to use the servo arm instead of a bellcrank (the large Airtronics arm is a perfect size match for the rudder control horn)?
3. Ideally, I'd like to have the elevator pull-pull cables attached to a mock-joystick which would be moved by the servo via a short control rod. But where to put the servo?
The real problem is thinking of a way to install the servos so that I can get at them for adjustments. I'd appreciate any photos of the "guts" of your planes that might jog my mind into finding a solution. Thanks.
ID:	135185   Click image for larger version
