RCU Forums - View Single Post - Engine for a CAP-232
Old 05-23-2004 | 12:25 PM
Spaceclam's Avatar
Spaceclam
Default RE: Engine for a CAP-232
try a ys 1.40. they are very expensive engines but you will absolutely love them. their throttle transition is seamless, it has more power than most 1.60 engines, and (the cool part) the idle adjustment is completely seperate from the transition adjustment so if you are mounted inverted, you can sit there and lean out the low end until it idles forever and the transition will not be too lean. they are competition engines, meaning they are designed to compete furiously with all other engines (including 2 stroke) for the same weight, but while offering the power of a top end 2 stroke they have the advantages of 4 strokes as well. trust me m8, you will enjoy that little engine.
