RE: Great Planes Shoestring
I had the same problem with mine. At the start of the taxi or at very slow speed or restriction on the ground (bumps , high grass, or depressions) it would nose over... If you got it rolling at a faster speed I could control it and the problem would end.
Jeff, I see you have a wood prop. For speed why not an APC prop? I started out with a wood prop and switched to APC and gain lots of speed.
