budweiser nitro start problems
first off i live in the mountains so im dealing with the altitude. second its brand new. third
i took it out htis morning with factory needle setings and it toook a while to start but it started was a little slugish and motor died when close to idle. so i set the idle screw up and tried the pull start it was hydro locked and i loosened glow plug put it back on tight now almost impossible to start. leaks right from glow plug so i tightened seem to stop then gets hydro locked again both trying to start in the water and dry start same problem any help would be great
travis
