RCU Forums - View Single Post - Battery Down Time ??
Old 05-23-2004 | 02:15 PM
TNRabbit's Avatar
TNRabbit
Default RE: Battery Down Time ??
The only "safe" bet is to check you batteries before every flight (tester). I charge my batteries when I return from the field, then keep them on trickle (@5-10 mAh) until I fly again. You can do this for several weeks. SR batteries (www.srbatteries.com) has a lot of good info on charging batteries.
