RE: Sig Somethin' Extra Build Time?
I built one in a month. They are one of the easier kits from what I've read on here. I read one post where someone did it in 4 days. I think you will get it done by early summer with no problem. The arf is 200.00 vs. 75.00 for the kit.
I didn't log my time but worked a little most every evening. What makes it so fast is that you use CA on one piece then the next piece, and on and on. This was my first kit. The only mistake I made was toward the end where you fit the fairing blocks. Everything was going good up to that point and I started getting a little lax reading the instructions.
