RE: More lapcat2/7.5 kb probs
actually its not the prop nut, the prop key was loose, so I fixed that but it still just revs... It only moves at idle... If you turn it revs and stops. I dont know what the prob is, I dont think the prop is slipping on the shaft. I tried trim up and down andI lifted the motor and dropped it same thing. I think im going to pick up a new prop shaft.
MY centerline for the prop is at the bottom on one of the sides... its not centered in the actual tunnel (middle) should it be? Also do I have to whip this thing a 1/2 throtle to drive it? I wasnt aware that if you slow down it will cavitate. Yet if I go slow its fine but it wont speed up just make a bunch of noise.
