RCU Forums - View Single Post - running down the batts?
Old 06-17-2003 | 09:34 PM
00hex
Default running down the batts?
To discharge the receiver battery on a glow plane properly you basically need a special battery discharger.
Since this is an electric plane, however, you've already got one stuck on the front (or behind the wing on the Wingo) spinning the propeller. The batteries will probably be just fine since you're discharging them almost all the way every time you fly. If you fly until the ESC cuts off they're probably very, very empty.
