RE: Receivers - Low vrs High
IF your receiver is one of the ones that is tuned to either the upper or lower part of the band, then, since you are channel 18, which is on the low end, you'd have a "low band" receiver. Low band is channel 35 and lower, high band are channel number above 35.
