RE: Viper wing bolt mods?
Do not tap holes in plywood, the threads will not last. Glue a maple block under the existing plate and tap into that. I use 10-24 flat head metal screws. It is not the screws that hold the wing on. It is the styrofoam glued to the block in the wing that holds the wing on.
Ed S
