ORIGINAL: Matt Kirsch
Do you remember how much you had to turn the low end in when you reset it? Your description just reminded me of a similar low-end issue I had. The low end needle actually affects fuel flow right up through full throttle if you have it set too lean.
No wonder OS ships them with the low end set so rich. It's harder to mess them up.
