ORIGINAL: coomarlin
ORIGINAL: Mark.v.
Hi again you guys, ok, final bit of help on the buying side please.
I am getting the U-CAN-DO 46, have opted for a Saito FA-72, i think the .91 would be a bit too much for me personally.
As far as the servos go, are the Futaba S3004's ok with an S3010 for the throttle, or do i need to look at something else, cost is a BIG priority for me, the engine and plane are costing me far too much already in my opinion, lol, but that's UK prices for ya !!!
Also, would my Hitec electron 6 rx be ok for this plane? And the prop being 14X4w is correct yes?
All help appreciated please, thanks guys.
That setup will work fine. You may try adding a 6V NiMH pack to get a bit more torque and speed out of the 3004's, but in general if you are on a budget they will work fine. The 14x4w is definately the right prop to use with the Saito 72.
The 14-4w will be for fine......but after beak in. i would start with a 13-4 or 13-6
