RCU Forums - View Single Post - How do you shave 1.5 lbs off an airplane?
Old 05-25-2004 | 07:36 PM
TNRabbit's Avatar
TNRabbit
Default RE: How do you shave 1.5 lbs off an airplane?
I assume that was an 1100 mAh battery vice 110 mAh? How is your CG? That may determine where you take off weight; if you end up having to add weight to balance it out, you may be defeating your purpose!
You are right about the on-board glow; you generally don't need it if you are using an OS "F" plug and fuel containing at least 15% nitro.
