RCU Forums - View Single Post - IT HAPPENED AGAIN!! HELP!!
Old 05-26-2004 | 06:59 AM
paranoid
Default RE: IT HAPPENED AGAIN!! HELP!!
Thanks for your help,
Just been over it, all tail controls smooth and correct. gear def. not slipping, hub's not rotating(this has happened before).
Yes this does only happen when i give sharp input on rudder.
I did however notice that i was only getting approx 30 deg right and 45-50 deg left on the servo, allowing for the fact it " holds to each side when stationary". So I hooked the servo direct to the rec. and it centered to the left. Repositioned arm so now i get 45deg each way with gyro hooked up. maybe i wasnt getting enough travel to compensate?
It could be a drop in tail rpm but cant detect a change in the head speed when it happens. I do know it loses power as it gets hotter. Having a scale body doesnt help i suppose.
Thanks again
JA
