RCU Forums - View Single Post - Wrong voltage reading on Hitec Flash 5 tx
Old 05-26-2004 | 10:34 AM
J_R
Default RE: Wrong voltage reading on Hitec Flash 5 tx
Jackster00
KW_Counter's comment about applying a load is the key. You can not measure the voltage without a load and get the correct reading. When the Tx is on, the load is automatically applied. Either measure the voltage when the unit is on, or apply a load to the battery when it is checked.
If, on the other hand, you are checking it when the unit is on, then you do need to send it back.
