RCU Forums - View Single Post - Hitec Flash 5 SX with Avistar Select
Old 05-26-2004 | 08:56 PM
av8r1's Avatar
av8r1
Default RE: Hitec Flash 5 SX with Avistar Select
Thanks Gary. It's ok, but it's kind of hilly and there's too many trees. But you can't beat the drive to the field. [8D]
BTW, I got replies from Futaba and Hobbico which seem to indicate that the Hitec Flash 5 SX should work with the Futaba rx in the Avistar, since Hitec's rx requirements are negative shift PPM, and PPM just means FM.
