RCU Forums - View Single Post - Wrong voltage reading on Hitec Flash 5 tx
Old 05-26-2004 | 10:20 PM
nitro bear
My Feedback: (12)
Default RE: Wrong voltage reading on Hitec Flash 5 tx
You may have a problem with the tx switch. I did. In my case all you had to do was push the switch just a little and the volts would go all over the place. Tx was sent to Hitec where they not only replaced the switch but the circuit board behind it as well. If that is the case with yours, I wouldn't think of using it until it was serviced. Just my .02
