RCU Forums - View Single Post - Phoenix Sonic 25 Low Wing ARF
Old 05-26-2004 | 11:33 PM
AQ500's Avatar
AQ500
Default RE: Phoenix Sonic 25 Low Wing ARF
I can't remember the size fuel tank that came with it since I made mine into a twin with twin 4 ounce tanks in the engine nacelles. The tank that comes with the plane is probably around 6 ounces.
I played around with the pushrod installation and found a configuration that required no bends. Here are some pictures. I don't have a throttle servo in the fuselage, so the install will have to be different.
ID:	136853   Click image for larger version
ID:	136854   Click image for larger version
