RCU Forums - View Single Post - Real Flight G2 Simulator
Old 05-27-2004 | 08:53 PM
IFlySlowPlanes
Default RE: Real Flight G2 Simulator
Actually, most of the turning is caused by the change in the lift vector when you bank the airplane in one direction or another. If you think of the lift component of a flying machine (remember the four forces of flight?....lift, weight, thrust, and drag) as an arrow pointing straight up from the center of the wing, you can imagine that this imaginary arrow is always pointed perpendicular to the wing (meaning if the wing banks left, the imaginary arrow also tilts the same amount toward the inside of the bank). The wing continues to provide lift no matter which way you point it, but the "lift vector" changes depending on if you're flying wings-level or banked in one direction or another. Bank left, and the lift vectormoves to the left also, which is what causes the turn. The rudder meanwhile is used to make the turn coordinated (or if not used correctly, the airplane will slip or skid through the turn, The airplane will still turn...it just isn't as pretty ;-)
You'll need the rudder mostly for takeoffs (to keep the plane tracking straight...it wants to swing left due to torque and a couple of other factors) and during climbout to a lesser degree. For most trainers, you'll barely use the rudder after that except on landing to keep the thing going the way you want it.
Have fun learning! That's a great program and good training for the real thing (especially practicing flying when the plane is headed at you!).
Regards,
David
