RCU Forums - View Single Post - Avistar or tower hobbies trainer?
Old 05-28-2004 | 07:45 AM
Free Fall
Default RE: Avistar or tower hobbies trainer?
I started building the Tower Trainer MKII, yesterday & have a question.
While browsing the "Tech Notes", at Tower, it noted, Additional requirements: ..... Servos: Four Standard (1-Aileron, 1-elevator, 1-Throttle, 1-Rudder)
The use of standard servos was part of the deciding factor for choosing this trainer. I purchased the radio first, then the aircraft, so, I have 4 standard servos.
The Tower Assembly Instructions uses the term "aileron servo". I checked with Futaba website & discovered there is a difference between Futaba Aileron Servo, S9102 & the Futaba "Standard" Servo, S3004.
Which wing mounted servo did you use?
Thank you in advance.
bob
