RE: Building a DraganFlyer - need to mix speedcontrollers - HELP
a quick question
Pipefish, your english is not too bad at all. good times. However, i am curious. Can you make blades that look almost identical to the ones gws sells (common electric blades) but in a counter rotating set for a 3mm shaft?
