RCU Forums - View Single Post - Epoxy won't cure: help!
Old 06-21-2003 | 08:47 PM
Shihtzutan
Default Epoxy won't cure: help!
My guess is that you didn't mix it right!
Because you are working in a critical location, I'd remove the old stuff and start over by brushing denatured alcohol over it, whilst swabbing up the mess with a paper towel. You should be able to get most of it off this way, then reapply with a fresh coat of epoxy. Any remaining first layer should cure with a properly mixed second layer.
