RCU Forums - View Single Post - Saito 1.20 problem help.
Old 05-29-2004 | 03:53 AM
autoguns's Avatar
autoguns
Default RE: Saito 1.20 problem help.
Are you using a pump?....If not you may want to check the clunk in the fuel tank if that is okay then you may want to check all your lines...if everything is good I would try to richen it up just a bit.....other then that I dont know....I hope this helps you ....JW
