RCU Forums - View Single Post - I need help
Thread: I need help
Old 06-21-2003 | 11:06 PM
LouW's Avatar
LouW
Default I need help
1. Yes. Lock the glo starter to the plug until the engine is running, then after a moment, remove it.
2. Tighten the nut firmly (use a properly fitting wrench, not pliers) Press the starter just enough to turn the engine. It helps if the engine is not on the compression stroke when the starter is engaged.
