> The tank is not foam mounted and from the looks of things there is no way to add foam around it. <
Is the problem that the tank is so large that there is no space to add foam? It that is so you can buy a tank in a different size or shape that should have a smaller cross-section which will provide space for the foam. Sullivan has a large assortment of tank types at
www.sullivanproducts.com/
